This document was generated from CDN thread
Created by: Marwa Ads on 10-11-2010 10:18:39 AM
Dear All,
I am facing a problem when pushing URI Keypad:1 to 5 after opening the network configuration menu, it's not working also i tried to push the URI Key:NavUp & Key:NavDwn also not working. pushing any thing to the Cisco 7912 phone after opening the network configuration menu is not working.
could you please help me in this issue as i want to open the network configurations menu to enable DHCP programmatically. or provide me with the URL that open the network configurations menu.
Best Regards,
Marwa
Subject: RE: Cisco 7912 URI problem
Replied by: David Staudt on 10-11-2010 02:28:45 PM
I believe this behaviour is by design as a security measure to prevent remote tampering with the device. XML services communications are not secure, and it would be fairly simple for a malicious user to intercept the push credentials and reconfigure the device.
