Created by: Arnaud Blachon on 17-08-2010 11:47:30 AM Hi,
I'm currently trying to list every conferences booked on our Codian 8420, using conference.enumerate.
I made my script with PHP5, and my own XML-RPC library.
Classic protocol, step by step:
- Open a socket on HOST : PORT (fsockopen) - Write the request on this socket (fwrite) - Wait for the response (blocking read) - Then Get the response (fgets)
Here comes my problem, the response contains always only 4 conferences regardless the filter i'm using.
Is there any default configuration that sets the maximum number of elements in xml response ?
If someone has already had this problem and solved it ...
Best regards
Subject: RE: [Codian API] Problem with enumerate function Replied by: Staale Reitan on 19-10-2011 01:20:23 PM There's a parameter for returning more than 4 entries (why, I don't know).
Parameter name: moreThanFour (optional) Parameter type: Boolean Parameter description: Enables the call to return more than four conferences (up to 24)
