Created by: Mert Guray on 01-04-2009 05:03:52 PM Hi, I have implemented a configurable Decision element. In the settings tag i prefer the input parameter be extendable. So i defined it as:
<font size="2"> settingArray[2] = </font> new Setting("ContextDataName3", "ContextDataName3",<font size="2"> </font> " ", true, false, true,Setting.TEXTFIELD); It is ok with the element. When i use it in developing i can add new lines with the same name. But how can i read the inputs afterwards. It seems like it is anarray but the view is like it is adding with the same name. I think it must be a little different from the line below:
Subject: Re: New Message from Mert Guray in Customer Voice Portal (CVP) -General Dis Replied by: Janine Graves on 01-04-2009 05:25:51 PM In the doDecision use the method config.getSettingValues and it returns an array. Each entry of the array will match each entry from Studio settings tab.
Date: Wed, 1 Apr 2009 17:03:52 To: cdicuser@developer.cisco.com<cdicuser@developer.cisco.com> Subject: New Message from Mert Guray in Customer Voice Portal (CVP) - General Discussion - All Versions: Configurable Decision element
Mert Guray has created a new message in the forum "General Discussion - All Versions":
-------------------------------------------------------------- Hi, I have implemented a configurable Decision element. In the settings tag i prefer the input parameter be extendable. So i defined it as:
<font size="2"> String DataName3 = config.getSettingValue( </font> "ContextDataName3", decisionData); -- To respond to this post, please click the following link:
