This document was generated from CDN thread
Created by: Joost Van Der Made on 31-03-2011 03:16:30 AM
Hello Team,
I'm trying to connect SocialMiner to CUIC, but I got some problems with the CUIC fields.
Here are my fields : (SocialMiner is the DNS name of the server)
Database host : ${SocialMiner}
Port : 1526
Databasename : mmca_data
Instance : SocialMiner_mmca
Timezone : Europe/Amsterdam
Databaseuser ID : reportinguser
Password : hidden
charset : UTF-8
If I use this configuration I get the error :
java.sql.SQLException: com.informix.asf.IfxASFException: Attempt to connect to database server (SocialMiner_mmca) failed.
If I change the Database host into : SocialMiner, I receive an error :
java.sql.SQLException: INFORMIXSERVER does not match either DBSERVERNAME or DBSERVERALIASES.
Although the wikidocumentation is clear, I'm unable to create a connection between CUIC and Socialminer.
I found the answer at the SocialMiner logging :
The databasehost can be socialminer with all lowercase and the instances should also be with lowercase.
Now it's working.
Thanks.
Joost vd Made.
Subject: RE: Connection with CUIC
Replied by: Tod Famous on 09-06-2011 01:41:41 PM
fixed
