CVP Studio's Web Service Element data substitution is not working
97
This document was generated from CDN thread
Created by: Farhang Farid on 16-11-2009 10:08:28 PM
Greetings,
We are using CVP studio's out of the box Web Service element to integrate with a web service. When a hard coded data is used to send data as parameter , web service executes fine, however when a substitution tag such as (Data.Session.phone} is used to pass data to the web service element , the tag is replaced with the {0} and hence web service element is not executed properly.
Attached (StudioConfig.jpg) show the web service element configuration
"deployedConfig.jpg" shows the confgigurations of the web service element after deployment
"error.jpeg" shows the request as it is generated by CVP , it looks like the CVP VXML server does not substitute the parameters with values at run time
Subject: RE: CVP Studio's Web Service Element data substitution is not working
Replied by: SilviaF Baptista on 16-11-2009 10:51:34 PM
Hi Farhang,
CVP 7.0(2) ES3 has the fix for WebService substitution problem.  You can download it from CCO: http://www.cisco.com/cgi-bin/tablebuild.pl/a8d366899587b2d7a8919be553ce0fed
Silvia
Replied by: Farhang Farid on 17-11-2009 12:31:05 AM
Hi Farhang,
Silvia
Thanks Silvia,
This resolved my issue.
Replied by: Ganesh K on 04-08-2010 11:20:54 AM
wonderful ... this solution worked. I'm able to invoke a webservice by passing a parameter value set in the Call studio ....
So, CVP7.0 on top of it CVP7.0.2 patch and add to it CVP7.0.2_ES3 to get this working.
Replied by: David Lender on 19-11-2012 10:24:21 AM
The fix for this defect
<pre>CSCsv36803 Websrvs node doesn't substitute values when using session VARs
was also integrated into ES 29 which can be downloaded here
http://www.cisco.com/cisco/software/special/release.html?config=5709c7eb909490f8d5f330576a68867e</pre>
