Subject: RE: Determine if a device/phone can record (has built-in-bridge) Replied by: Abhishek Malhotra on 24-06-2010 05:45:08 AM In coming release, we are adding functionality to expose whether a Terminal(phone) has built in bridge enabled or not, so that should help but as of today this information is not exposed. This document was generated from CDN thread
Created by: Chikeobi Njaka on 23-06-2010 10:04:19 PM Dear Gang; I need to find a way to determine if a phone/device is a G-series phone. The XModel and XProduct enums do not include all the G series phones (such as 7906G). Does anyone know a way to determine if a phone is the newer G-series or better yet, if the phone is capable of recording using the Built-In-Bridge? I need to do this programmatically. Thanks
Subject: RE: Determine if a device/phone can record (has built-in-bridge) Replied by: Chikeobi Njaka on 24-06-2010 03:22:57 PM
Understood. In the meanwhile, is there a way, perhaps using a combination of AXL commands and/or IPPhone XML, that this can be "deduced"?
Subject: RE: Determine if a device/phone can record (has built-in-bridge) Replied by: David Staudt on 24-06-2010 03:35:47 PM Via AXL getPhone, there is a <builtInBridgeStatus> element (returns on/off/default.) If this element is present and 'on' or 'default' this may tell you want you want.
