Subject: RE: DTMF Barge In not working Replied by: Paul Tindall on 13-03-2013 07:17:05 PM Check your Nuance server has DTMF barge-in enabled for either MRCPv1 or v2 depending on which one you're using. There's a specific setting to enable it.
Subject: Re: New Message from Lucas Pepping in Customer Voice Portal (CVP) - CVP - A Replied by: Feroz Syed on 13-03-2013 07:26:58 PM Try setting bargein=true vxml property in that menu element. On Mar 13, 2013 7:16 PM, "Cisco Developer Community Forums" < cdicuser@developer.cisco.com> wrote:
> Lucas Pepping has created a new message in the forum "CVP - All Versions": > -------------------------------------------------------------- I have a 9 > option menu that has 'Barge In' enabled but DTMF does not barge in. DTMF > is not recognized until all audio is played. Also have Nuance configured > for ASR on this same menu. The ASR barge in works fine but the dtmf barge > in does not. > FYI, when ASR gateway adapter is not selected, the DTMF barge in works > fine. > Any thoughts/ideas? > -- > To respond to this post, please click the following link: > http://developer.cisco.com/web/cvp/community/-/message_boards/view_message/13000231or simply reply to this email. This document was generated from CDN thread
Created by: Lucas Pepping on 13-03-2013 07:13:53 PM I have a 9 option menu that has 'Barge In' enabled but DTMF does not barge in. DTMF is not recognized until all audio is played. Also have Nuance configured for ASR on this same menu. The ASR barge in works fine but the dtmf barge in does not. FYI, when ASR gateway adapter is not selected, the DTMF barge in works fine. Any thoughts/ideas?
Subject: RE: DTMF Barge In not working Replied by: Lucas Pepping on 14-03-2013 11:29:26 AM
Paul Tindall:
