Created by: null on 11-07-2005 03:47:33 PM We want to configure/play Form prompts (intial/noinput/nomatch) which are set dynamically , To achieve this I have written my own custom FROM class(NewCustomAudioForm) and DynamicConfig class(PlayDynamicFormPrompts) .
The reason to write to our own form class is default FROM element in the builder requires INITIAL audio to be provided
Following are the error messages during run time SERVER ERROR: An element encountered an exception of type com.audium.server.xml.ElementConfigException with the message: The setting maxnbest does not exist.
Subject: RE: Dynamic Prompts For a Form Element Replied by: Vance Vagell on 11-07-2005 04:12:31 PM Hi Chaitra,
The error message:
[code:1:b798f33012] The setting maxnbest does not exist. [/code:1:b798f33012]
is appearing because the base class of your new Form element (MFoundationForm) expects this setting to exist and have a value. Since you are using dynamic configuration, you have two options:
1) Use a base configuration that includes a value for maxnbest. 2) Have your dynamic configuration class set the value of maxnbest at runtime.
For more information about Dynamic Configuration (including how to leverage a base configuration), please refer to the Programmer Guide.
Hope this helps, Vance
Subject: Dynamic Prompts For a Form Element Replied by: null on 11-07-2005 05:32:26 PM Hi,
As per your instruction , I added following lines of code to my PlayDynamicFormPrompts java program ADDED---->defaults.setSettingValue("maxnbest","1"); After the changes Following was the error SERVER ERROR: An element encountered an exception of type com.audium.server.voiceElement.ElementException with the message: At least one grammar setting should be configured for NewCustomAudioForm_01 voice element.
Moreover, as stated in JavaDocs available at http://www.audiumcentral.com/supportcenter/viewtopic.php?t=1101, you can add another count for NoMatch and/or NoInput events using the following code: [code:1:be0589d04d] VEvent nomatchEvent = VEvent.getNew(pref, VEvent.NOMATCH); nomatchEvent.addCount(X); [/code:1:be0589d04d]
where X is the desired count.
Hope this helps, Michael
Subject: Dynamic Prompts For a Form Element Replied by: null on 11-07-2005 09:02:00 PM Hi,
Sorry for the confusion , I wanted to play in the form say
"this is no match prompt one" when NOMATCH1 occurs "this is no match prompt two" when NOMATCH2 occurs
Since I am using dynamic configuration to play prompts , I want provide all the prompts in the same class
Subject: Dynamic Prompts For a Form Element Replied by: null on 12-07-2005 02:00:01 PM Hi,
