This document was generated from CDN thread
Created by: Valentin Ichim on 15-02-2011 08:38:21 AM
I use an Edge 95 with MS to make 2 calls : one to another Edge and one to TCS. I want to have on the DVI output only the remote main ( from Edge ) and local main in PIP. How I could remove the TCS from the layout ? What multipoint layout should be choosen ? I try to make a different layout ( configure a PictureProgram from Virtual Monitor ) but the telnet xconfig pictureprogram is not a valid syntax.
Any idea ?
Thank you !
Subject: RE: Edge 95 Virtual Monitor
Replied by: Roger Boe on 15-02-2011 08:41:54 AM
Hi Valentin,
The Edge 95 doesn't support the picture programs. You will need the codec 3000MXP or codec 6000MXP for this.
Best regards
Roger
Replied by: Valentin Ichim on 15-02-2011 09:57:33 AM
Hi Roger,
Thanks for quick reply.
How could I remove the Recording panel ( TCS ) from the layout in a 3 way call ( 2 edges and TCS ) ?
I think to setup the MutiSite layout as Voice Switched and the TCS will not appear ( as there is no audio feedback from TCS ) and to force a PIP display of the localmain.What should I configure on Edge in order to have always localmain display in PIP ? I tried with xcommand pipshow virtualmonitor: 1 picture: localmain position: bottomright but I don't know if I should send this each time.
Thank you
Valentin
