cdnadmin
Level 11
Level 11
Subject: Re: New Message from Francois Leclair in Extension Mobility API (EMAPI) - E
Replied by: Sascha Monteiro on 10-06-2011 12:51:54 AM
Are you sending the request to the EM Api? (it looks like you are trying to parse this on a phone..??)
you need to POST the request xml from your application to;
https://<server>:8443/emservice/EMServiceServlet
This document was generated from CDN thread
Created by: Francois Leclair on 10-06-2011 12:38:35 AM
Hi team,
This is my first try at EM API and would need your help.  I'm trying to do the following command but I receive an error.
Would you know what I did wrong ?
Many thanks,
Francois
<request>
     <appInfo>
          <appID>SunRay</appID>
          <appCertificate>gemsoft</appCertificate>
     </appInfo>
     <login>
          <deviceName>SEP00169DEF0C7F</deviceName>
          <userID>1234</userID>
          <deviceProfile>User1</deviceProfile>
          <exclusiveDuration>
               <time>60</time>
          </exclusiveDuration>
     </login>
</request>
This is the response I'm receiving :
<CiscoIPPhoneText>
    <Title>Login response</Title>
    <Text>Login Unsuccessful</Text>
    <Prompt>Login is unavailable (207)</Prompt>
    <SoftKeyItem>
        <Name>Exit</Name>
        <URL>SoftKey:Exit</URL>
        <Position>1</Position>
    </SoftKeyItem>
</CiscoIPPhoneText>
Francois
Jon Snipes
I was running into the same thing.  Restarting EM service resolved.
