Created by: Marat Rabidinov on 26-05-2011 03:54:15 AM I need to create a tcl script, which will be initiated by incoming call into Cisco Router. The script must make a multiple calls to many phones and play media files. But when initiated call is down, the script is stoped. But I need that the script goes on to make a calls and plays a media files. How can I make to not stop execution of tcl script after the initiated call is closed?
Subject: RE: How to go on tcl script execution after call close Replied by: Max Lamovich on 26-05-2011 05:07:16 AM Hi Marat!
You need use session tcl application, You can find about that in "Tcl IVR 2.0 Programming Guide" chapter "Application Instances" (1-38) This type of tcl Application running(initiated) without incoming call and in this application You can make external request through http or radius, get data from request and start outgoing call.
I wrote similar application, but without play sound.
service srvtest flash:service.tcl param debug 0 param cbsrvnum ______NumberforCALL____
set inf_leg [infotag get evt_legs] msgSend "ID_LEG:$inf_leg"
leg disconnect $inf_leg
set leg_st [infotag get evt_status] msgSend "Status:$leg_st" }
proc act_CallDone { } { msgSend "act_CallDone"
#set ev [infotag get evt_event] #msgSend "Event $ev" #set ev [infotag get evt_status] #msgSend "Status event $ev"
act_Timer }
proc act_CallSetup { } { msgSend "act_CallSetup"
global cb_srv_num
set destination $cb_srv_num set callInfo(accountNum) ____Account____ set callInfo(originationNum) 1212121212 set callInfo(redirectCount) 1 set callInfo(alertTime) 1 leg setup $destination callInfo leg_outgoing }
proc act_Ignore { } { set ev [infotag get evt_event] msgSend "is ignoring event $ev" }
proc msgSend {str} { global debug global myname if {$debug == 1} { puts "$myname $str" } }
#---------------------------------- # State Machine #---------------------------------- set fsm(any_state,ev_session_indication) "act_Session same_state" set fsm(any_state,ev_session_terminate) "act_Terminate same_state" set fsm(any_state,ev_call_timer0) "act_Timer same_state" set fsm(any_state,ev_authenticate_done) "act_AuthDone same_state"
set fsm(CALL,ev_call_timer0) "act_Timer same_state" set fsm(CALL,ev_setup_done) "act_CallSetupDone same_state" set fsm(CALL,ev_disconnect_done) "act_CallDone start_state" set fsm(CALL,ev_disconnected) "act_CallDone start_state"
set fsm(any_state,ev_disconnected) "act_Timer same_state" set fsm(any_state,ev_any_event) "act_Ignore same_state"
fsm define fsm start_state
____Account____ - for radius ______NumberforCALL____ - Number for outgoing call
Subject: RE: How to go on tcl script execution after call close Replied by: Raghavendra Gutty Veeranagappa on 26-05-2011 05:34:00 AM Hi Marat,
please raise developer support case using below link we will help you to create tcl script for your requirements, since forum is to discuss only simple queries.
