This document was generated from CDN thread
Created by: Manas Varma on 26-08-2010 07:33:08 AM
Hi All,
I am using Call Manager 6.X cluster . Please help me in finding the service using which / or any other way by which i can remotely change the speed and duplex of IPPhones. It doesn't matter if the procedure is not very secure. I just need to some how accomplish that. Please Help, its very urgent .
Manas
Subject: RE: How to Update Network Speed and Duplex
Replied by: David Staudt on 26-08-2010 01:20:09 PM
In the normal use case, the phone auto-negotiates its speed/duplex via CDP/LLDP from the attached switch port. Those settings can be overriden, but only via the phone's manual configuration. There is no UCM-side API that can make this change, you might be able to use the CiscoIPPhoneExecute and 'Key:xxx' commands to simulate phone button pushes to negotiate the configuration menu (blindly) but I think my recollection is that the phone will not enter config mode via simulated keypresses. For demo/lab purposes it might be worth a shot.
