Created by: Alexander Pluzhnikov on 06-06-2012 05:57:09 AM Hello. Can somebody help me? I have some tcl ivr script and I need to change it but I don’t know how. I have script which play menu message (tree items) during incoming calls and offer to choose one item. Now script work so if user choose item 1 script connect him to operator 1, if the user choose item 2 script connect him to operator 2 and if user choose item 3 script connect him to operator 3. I need make so then user choose item 1 script play message “please enter extension number” and offer user to enter extension number after that script connect user to this extension number. Item 2 and item 3 need to work as before. This is my script: #------------------------------------------------------------------ # # #------------------------------------------------------------------- # proc init { } { global param1 global selectCnt global callInfo global legConnected global maxExtensionLen set param1(interruptPrompt) true set param1(maxDigits) 1 set param1(abortKey) * set param1(terminationKey) # set selectCnt 0 set legConnected false } proc init_ConfigVars { } { global destination global aaPilot global oprtr global menu1 global menu2 global menu3 global maxExtensionLen # aa-pilot is the IVR number configured on the gateway to be used by the customer # operator is the operator number for assisted calling if [infotag get cfg_avpair_exists aa-pilot] { set aaPilot [string trim [infotag get cfg_avpair aa-pilot]] } else { set aaPilot "NONE" } if [infotag get cfg_avpair_exists operator] { set oprtr [string trim [infotag get cfg_avpair operator]] } else { set oprtr "NONE" } if [infotag get cfg_avpair_exists line1] { set menu1 [string trim [infotag get cfg_avpair line1]] } else { set menu1 "NONE" } if [infotag get cfg_avpair_exists line2] { set menu2 [string trim [infotag get cfg_avpair line2]] } else { set menu2 "NONE" } if [infotag get cfg_avpair_exists line3] { set menu3 [string trim [infotag get cfg_avpair line3]] } else { set menu3 "NONE" }
if [infotag get cfg_avpair_exists max-extension-length] { set maxExtensionLen [string trim [infotag get cfg_avpair max-extension-length]] if { $maxExtensionLen < 0 } { call close } } else { set maxExtensionLen 4 } } proc init_perCallVars { } { puts "\nproc init_perCallvars" global ani global digit_enabled global fcnt global retrycnt global dnis set fcnt 0 set retrycnt 2 set ani "" set dnis "" set digit_enabled "FALSE" set ani [infotag get leg_ani] puts "\nANI $ani" set dnis [infotag get leg_dnis] puts "\nDNIS $dnis" } proc act_Setup { } { global param1 global selectCnt global dest global beep global callInfo global dnis global fcnt global aaPilot global oprtr global menu1 global menu2 global menu3 global busyPrompt global legConnected puts "proc act_Setup" set busyPrompt _dest_unreachable.au set beep 0 init_perCallVars infotag set med_language 1 if { ($dnis == "") || ($dnis == $aaPilot) } { leg setupack leg_incoming leg proceeding leg_incoming leg connect leg_incoming set legConnected true puts "\nNo DNIS\n" set param1(dialPlan) true leg collectdigits leg_incoming param1 media play leg_incoming _welcome.au %s1000 _enter_dest.au } else { set fcnt 6 leg setupack leg_incoming #handoff callappl leg_incoming default "DESTINATION=$dnis" set callInfo(alertTime) 30 leg setup $dnis callInfo leg_incoming fsm setstate HANDOFF }
} proc act_GotDest { } { global dest global maxExtensionLen global destExtLen global callInfo global oprtr global menu1 global menu2 global menu3 global busyPrompt puts "\n proc act_GotDest" set status [infotag get evt_status] set callInfo(alertTime) 30 if { ($status == "cd_004") } { set dest [infotag get evt_dcdigits] if { $dest == "0" } { set dest $oprtr } #handoff callappl leg_incoming default "DESTINATION=$dest" leg setup $dest callInfo leg_incoming } elseif { ($status == "cd_001") || ($status == "cd_002") } { set dest $oprtr #handoff callappl leg_incoming default "DESTINATION=$dest" leg setup $dest callInfo leg_incoming } else { if { $status == "cd_006" } { set busyPrompt _dest_unreachable.au } puts "\nCall [infotag get con_all] got event $status collecting destination" set dest [infotag get evt_dcdigits] if { $dest == "0" } { set dest $oprtr #handoff callappl leg_incoming default "DESTINATION=$dest" leg setup $dest callInfo leg_incoming } elseif { $dest == "1" } { #set dest $oprtr set dest $menu1 #handoff callappl leg_incoming default "DESTINATION=$dest" leg setup $dest callInfo leg_incoming } elseif { $dest == "2" } { set dest $menu2 #handoff callappl leg_incoming default "DESTINATION=$dest" leg setup $dest callInfo leg_incoming } elseif { $dest == "3" } { set dest $menu3 #handoff callappl leg_incoming default "DESTINATION=$dest" leg setup $dest callInfo leg_incoming } else { act_Select } } } proc act_CallSetupDone { } { global busyPrompt global legConnected set status [infotag get evt_status] if { $status == "ls_000" } { puts "\n Connection success" handoff appl leg_all default act_Cleanup } else { if { $legConnected == "false" } { leg proceeding leg_incoming leg connect leg_incoming set legConnected true } puts "\n Call failed. Play prompt and collect digit" if { ($status == "ls_007") } { set busyPrompt _dest_busy.au } act_Select } } proc act_Select { } { global destination global promptFlag2 global destBusy global param1 global fcnt global retrycnt global busyPrompt
puts "\n proc act_Select" set promptFlag2 0 set param1(interruptPrompt) true set param1(abortKey) * set param1(terminationKey) # set param1(dialPlan) true set param1(dialPlanTerm) true leg collectdigits leg_incoming param1 if { $fcnt < $retrycnt } { media play leg_incoming $busyPrompt %s500 _reenter_dest.au incr fcnt fsm setstate GETDEST } else { act_DestBusy } } proc act_DestBusy { } { puts "\n proc act_DestBusy" media play leg_incoming _disconnect.au fsm setstate CALLDISCONNECT } proc act_Cleanup { } { call close } requiredversion 2.0 init init_ConfigVars #---------------------------------- # State Machine #---------------------------------- set fsm(any_state,ev_disconnected) "act_Cleanup same_state" set fsm(any_state,ev_disconnect_done) "act_Cleanup same_state"
set fsm(CALL_INIT,ev_setup_indication) "act_Setup GETDEST" set fsm(GETDEST,ev_collectdigits_done) "act_GotDest HANDOFF" #set fsm(HANDOFF,ev_returned) "act_CallSetupDone CONTINUE"
set fsm(HANDOFF,ev_setup_done) "act_CallSetupDone CONTINUE" set fsm(CALLDISCONNECT,ev_media_done) "act_Cleanup same_state"
fsm define fsm CALL_INIT
Subject: RE: I need help with TCL IVR script Replied by: Anusha Kannappan on 06-06-2012 06:38:59 AM Hi Alexander,
You could download and refer the its-CISCO.2.0.3.0.zip from the following location
Subject: RE: I need help with TCL IVR script Replied by: Alexander Pluzhnikov on 06-06-2012 10:21:23 AM Thank you for your help Anusha. I downloaded this script and made some changes. And now I have a question about new script. Can you advice me how I can fix a problem with the new my script. When a user call to IVR and press "9" IVR make transfer the call to fax extension but not immediately yet after some pause (inter-digit timeout). I need to make transfer the call to fax extension immediate without pause. Can you advise me how I can fix this pause.
Subject: RE: I need help with TCL IVR script Replied by: Alexander Pluzhnikov on 06-06-2012 10:31:01 AM this is my new script: #
proc init { } { global param1 global selectCnt global callInfo global legConnected global maxExtensionLen global greetingClose
set param1(interruptPrompt) true set param1(abortKey) * set param1(terminationKey) # set param1(interDigitTimeout) 4
proc init_ConfigVars { } { global destination global aaPilot global oprtr global fax global maxExtensionLen
if [infotag get cfg_avpair_exists aa-pilot] { set aaPilot [string trim [infotag get cfg_avpair aa-pilot]] } else { set aaPilot "NONE" } if [infotag get cfg_avpair_exists operator] { set oprtr [string trim [infotag get cfg_avpair operator]] } else { set oprtr "NONE" } if [infotag get cfg_avpair_exists faxnumber] { set fax [string trim [infotag get cfg_avpair faxnumber]] } else { set fax "NONE" } if [infotag get cfg_avpair_exists max-extension-length] { set maxExtensionLen [string trim [infotag get cfg_avpair max-extension-length]] if { $maxExtensionLen < 0 } { call close } } else { set maxExtensionLen 4 } }
proc act_Setup { } { global param1 global selectCnt global dest global beep global callInfo global dnis global fcnt global aaPilot global oprtr global fax global busyPrompt global legConnected global greetingClose
puts "proc act_Setup" set busyPrompt _dest_unreachable.au set beep 0 set nowHour [clock format [clock seconds] -format %R] init_perCallVars infotag set med_language 1
if {[infotag get cfg_avpair_exists outworkhour]} { set owHour [infotag get cfg_avpair outworkhour] } else { set owHour "18:00 09:00" }
set start [lindex $owHour 0] set end [lindex $owHour 1] puts "\n--- SUNRISE Start is $start End is $end NowHour is $nowHour" set owYes 0 set cc [string compare $start $end] puts "\n--- SUNRISE cc is $cc" if { $cc } { if { $cc == 1 } { puts "\n--- SUNRISE start > end" set cc1 [string compare $nowHour $start] set cc2 [string compare $nowHour $end] puts "\n--- SUNRISE cc1 $cc1 cc2 $cc2" if { $cc1 == 1 || $cc2 == -1 } { puts "\n--- SUNRISE match" set owYes 1 } } else { puts "\n--- SUNRISE start < end" set cc1 [string compare $nowHour $start] set cc2 [string compare $nowHour $end] puts "\n--- SUNRISE cc1 $cc1 cc2 $cc2" if { $cc1 == 1 && $cc2 == -1 } { puts "\n--- SUNRISE match" set owYes 1 } } } else { puts "\n--- SUNRISE start = end" } if { $owYes == 1 } { set greetingClose [ infotag get cfg_avpair outworkgreeting ] media play leg_incoming $greetingClose fsm setstate CALLDISCONNECT } }
proc act_GotDest { } { global dest global maxExtensionLen global destExtLen global callInfo global oprtr global fax global busyPrompt puts "\n proc act_GotDest" set status [infotag get evt_status] set callInfo(alertTime) 30 puts "\n STATUS: $status" puts "\n MAXEXTENSION: $maxExtensionLen" if { ($status == "cd_004") } { set dest [infotag get evt_dcdigits]
set destExtLen [string length $dest] puts "\n DESTLEN: $destExtLen" set extLength [expr $maxExtensionLen - $destExtLen] if { $dest == "0" } { set dest $oprtr } if { $dest == "9" } { set dest $fax } puts "\n extLength: $extLength"
#handoff callappl leg_incoming default "DESTINATION=$dest" if {($maxExtensionLen > 0) && ($extLength >= 0)} { leg setup $dest callInfo leg_incoming } else { set busyPrompt _bacd_invalidoption.au act_Select } } elseif { ($status == "cd_001") || ($status == "cd_002") } { set dest $oprtr #handoff callappl leg_incoming default "DESTINATION=$dest" leg setup $dest callInfo leg_incoming } else { if { $status == "cd_006" } { set busyPrompt _dest_unreachable.au } puts "\nCall [infotag get con_all] got event $status collecting destination" set dest [infotag get evt_dcdigits] if { $dest == "0" } { set dest $oprtr #handoff callappl leg_incoming default "DESTINATION=$dest" leg setup $dest callInfo leg_incoming } elseif { $dest == "9" } { set dest $fax #handoff callappl leg_incoming default "DESTINATION=$dest" leg setup $dest callInfo leg_incoming } else { act_Select } } }
proc act_Select { } { global destination global promptFlag2 global destBusy global param1 global fcnt global retrycnt global busyPrompt puts "\n proc act_Select"
set fsm(any_state,ev_disconnect_done) "act_Cleanup same_state" set fsm(CALL_INIT,ev_setup_indication) "act_Setup GETDEST"
#set fsm(HANDOFF,ev_returned) "act_CallSetupDone CONTINUE" set fsm(HANDOFF,ev_setup_done) "act_CallSetupDone CONTINUE"
Subject: RE: I need help with TCL IVR script Replied by: Anusha Kannappan on 07-06-2012 05:41:26 AM Hi Alexander,
As it is clearly stated in the script it has to wait for interDigitTimeout and then only do a leg setup. Please try changing the time less than the specified in the script.
