Created by: ROD TAGUCHI on 13-06-2012 02:53:15 PM When doing an initial build using WebEx Social-2.6.1.09860.3.ova I am getting stopped at the director node setup. Step 3. when I open browser to http://virtual_machine_ip, i get the default Centos webpage, not the director control panels. If I try to open http://virtual_machine_ip/director, i get 404 URL/director was not found on this server. Question, is this an issue with the OVA or is there a way to overcome this error? A couple of other things to note. 1. the setup GUI using admin logon did not give me an option to set NTP server. 2. from Shell, if I do a service puppet debug at this time, i get the following error.
3. from Shell, if I do a puppet cert --list --all, i get many errors.
Subject: RE: Initial Clean Build WebEx Social-2.6.1.09860.3.ova Director setup fails Replied by: ROD TAGUCHI on 13-06-2012 04:04:29 PM Ok, Jumped the gun here. The errors were reporting because the Director node had not completed setup. After waiting for some time, I tried using the default URL as in the setup guide and it is working now. Lesson learned. Must give ample time during setup for the director node to complete setup before moving to next step. We lose access to root with this build. Not sure how that would be handled with upgrades, as my Albani instance that was upgraded retained root access.
