cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Viki Rai on 16-11-2010 06:54:03 AM
Is there any way to integrate Unity Connection with CUCM.
I am more interested in the integration of users between Unity Connection and CUCM.
Just a lit over it is really appreciable.
Subject: RE: Integrate Unity Connection users with CUCM
Replied by: David Wanagel on 17-11-2010 01:02:25 PM
The ability to import a user from CUCM is being added to 8.5 for CUCMBE systems.  The effect will be the same as if they had been imported using the administrator GUI.
-Dave
Replied by: Viki Rai on 30-11-2010 01:46:49 PM
Using Unity Connection GUI, if I import users
from CUCM to CUC (configured AXL server in CUC), only users having
primary extension is getting imported into CUC.
When I try to do the same through service call, all the users are getting imported irrespective of the user is having
extension or not. I might use the wrong webservice call.
Suggest me a solution for the above problem.
Replied by: David Wanagel on 30-11-2010 02:13:08 PM
Can you clarify what service call you are using and the version of the system you are on?  AXL import is not supported using CUPI, so I am not clear on what call you are making.
-Dave
