Walkthrough Wednesdays
Is 3PCC (Third Party Call Control) possible with CiscoTSP?
306
This document was generated from CDN thread
Created by: Mike Roberts on 12-02-2010 10:45:49 PM
I am trying to monitor incoming calls (for caller id information) and create calls from an application running on a PC next to a VOIP phone. The PC has no telephone hardware or software other than the TSP. Is this possible? Is there a certain version of TAPI, CiscoTSP, or phone system that is required? Thanks.
Subject: RE: Is 3PCC (Third Party Call Control) possible with CiscoTSP?
Replied by: David Staudt on 13-02-2010 12:44:05 AM
In fact, 3PCC - using a TAPI application to monitor/control a Cisco IP phone - is probably the most common usage.  If an IP phone is on the TSP user's 'associated devices' list, then it will be included in the list of devices the TAPI application can monitor/control.  Depending on what you want to do, you can receive events for incoming calls, obtain the caller/calling numbers, answer or transfer the call, etc.
Content for Community-Ad
