This document was generated from CDN thread
Created by: Christopher Gentsch on 10-03-2011 12:42:37 AM
We have a room where the C60 is periodically reverting to a state where echo control on audio inputs is being enabled, having manually turned it off since there are ClearOne mixers handling a large number of student mics.
Our Crestron programmer's review of the module is that it doesn't seem to even support changing this setting and we are not doing anything outside of the module (v1.1). Codec is on TC3.1.3
It seems odd that this is the only parameter that is changing, so would appreciate any ideas for tracking this down.
Thx
