Created by: Jon Finke on 02-12-2011 12:30:33 PM Our telecom manager wants a way for folks to be able to unlock their credential (which got locked via bad pin attempts), without resetting the PIN itself. We are running 7.1.3.68. I tried sending my normal pin reset code with the new pin ommitted: https://xxxx.rpi.edu/vmrest/users/801373ed-732f-4ddc-a776-db8628e4c4f8/credential/pin <Credential><Hacked>false</Hacked><HackCount>0</HackCount></Credential> and got the following in response: <ErrorDetails><errors> <code>IMS_ERROR</code> <message>There is no credential value for the given credential name</message> </errors></ErrorDetails>
Subject: RE: Is there a way to unlock (unhack) a PIN without resetting it? Replied by: Jeff Lindborg on 05-02-2012 01:14:06 PM This should be possible - I just send the same PUT command with the XML looking like this:
note the use of 0 instead of "false" - the locked shouldn't be necessary but on my test app it's included in the larger "clear locked account" method...
Subject: RE: Is there a way to unlock (unhack) a PIN without resetting it? Replied by: Jon Finke on 14-02-2012 05:34:28 PM Thanks for the info! - I will give it a try next time the CUPI interface floats to the top of my project queue.
