This document was generated from CDN thread
Created by: Jeremy Ousley on 20-09-2011 10:11:03 PM
Is there any way to "turn the module off" using a device channel or some other way. I am transfering a large amount of date into and out of the codec which is not supported by the module. Using PASSTHRU and PASSBACK slow down the process and actually causes the module to loose its "HEARTBEAT" from the codec.
If there is a way to turn the module off it would be helpful.
Thanks!
