on 01-24-2014 02:09 PM
<!--[if gte mso 9]><xml>
<w:WordDocument>
<wiew>Normal</wiew>
<w:Zoom>0</w:Zoom>
<wunctuationKerning />
<walidateAgainstSchemas />
<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>false</w:IgnoreMixedContent>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:Compatibility>
<w:BreakWrappedTables />
<w:SnapToGridInCell />
<w:WrapTextWithPunct />
<w:UseAsianBreakRules />
<wontGrowAutofit />
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><!--><!--[if gte mso 9]><xml>
<w:LatentStyles DefLockedState="false" LatentStyleCount="156">
</w:LatentStyles>
</xml><!--><!--[if gte mso 10]>
<style>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language0400;
mso-fareast-language0400;
mso-bidi-language0400;}
</style>
Typically,
Nortel PBX uses the History-Info field to send redirecting number information,
while the Cisco UCM uses the Diversion header. This affects how calls are
treated when redirected to a voice mail system over an SIP trunk. Cisco Unified
Communications Manager release 8.5 provides the ability to translate either
Diversion headers into History-Info headers or History-Info headers to
Diversion headers via SIP Normalization Script. Information on how to configure
a SIP Normalization Script converting History-Info headers into Diversion
headers and vice versa is provided within this document.
A code was developed.
".............SCRIPTTTT.................."
<w:WordDocument>
<wiew>Normal</wiew>
<w:Zoom>0</w:Zoom>
<w:Compatibility>
<wontGrowAutofit />
</w:Compatibility>
</w:WordDocument>
</w:LatentStyles>
<style>
font-size:10.0pt;
</style>
<!-->The
Cisco UCM-Software Script should be applied at SME SIP trunk toward Nortel PBX
for UC Voice Mail center MWI, Move Allow Option and Update. For now, please
copy and paste to note pad and save it using txt format. Review the script to
ensure that it is not corrupted before upload to the normalization section.
Things arent still working.
Works fine over QSIG not over SIP.
