cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Erik Solbu on 17-10-2011 10:51:24 AM
When trying to launch the TC Console application I receive an error message (Unable to launch the application).
Running on Windows XP SP3, but also tried on a PC running Vista with the same result.
On my home (private) PC running Windows 7, no problem, but from this I am not able to connect to the C60 codecs.
Also tried to disable virus protection and set IE to minimum security. Same result, not able to lauch.
Does anybody have a walk around solution?
Subject: RE: Not able to launch TC Console
Replied by: David Bruun-Lie on 17-10-2011 12:17:46 PM
try clearing your Java-cache. We have seen this kind of behavior before and clearing old instances of the TC console has resolved the issue.
Cheers,
David
Replied by: Erik Solbu on 20-10-2011 10:19:13 AM
Did clearing of Java cache. Did not help, same result
