Community Helping Community
Pin out for SUB-D9 -->HD cam port?
66
This document was generated from CDN thread
Created by: Markus Schuermann on 16-09-2009 06:39:19 PM
Does anybody have the pinout for HD Cam port with signals? Preferred 6000MXP and or 3000MXP.
Thanks.
Subject: RE: Pin out for SUB-D9 -->HD cam port?
Replied by: Roger Boe on 17-09-2009 10:31:34 AM
These systems use a proprietary TANDBERG High Speed Interface to transfer video and as such you can't make your own cable. The cable has to be very high quality, short distance and category 7.5. If you need to extend the cable you must use a TANDBERG Video Switch.
-Roger
Replied by: Marko Laurits on 03-11-2009 05:32:02 PM
Look Tandberg MXP reference guide for system integrators to see the pin-out.
We have used "Cat-7" cable to extend HD Camera signal from equipment rack in one room to the camera in another room. It works ok.
Content for Community-Ad
FusionCharts will render here
