This document was generated from CDN thread
Created by: Matt K. on 25-05-2010 07:28:09 PM
I am trying to play a US mailing address using TTS. I added the <say-as> tag and I see that in that CVP (Audium) logs it is generated as :
<prompt bargein="true"><say-as interpret-as="address">555 Main St. Atlanta, GA </say-as></prompt>
However, when I call my application, system terminates the call and I see in the log files badfetch error. TTS is working fine without <say-as> tag but obviously it does not play the text as an address which I want.
Please let me know if there is any way to get around this. We are using Nuance RealSpeak.
Matt
Subject: RE: Playing Address using TTS
Replied by: Matt K. on 26-05-2010 06:54:03 PM
I will try and let you know but we cannot replace "St." with "Street" since we are getting the addresses from databaes and "St." does not mean Street all the time. One example is "St. lewis".
Matt
Replied by: Yawming Chen on 26-05-2010 03:28:55 PM
I am still looking for if "adress" is supported. In the mean while I think maybe we can try this:
<say-as interpret-as="number">555</say-as>
<say-as interpret-as="letters">Main Street Atlanta Georgia</say-as>
Replied by: Yawming Chen on 26-05-2010 08:22:45 PM
Please try <say-as type="address">
The following types are supported:
acronym
number:ordinal
number:digits
telephone
date:dmy
date:mdy
date:ymd
date:ym
date:my
date:md
date:y
date:m
date:d
time:hms
time:hm
time:h
duration:hms
duration:hm
duration:ms
duration:h
duration:m
duration:s
currency
measure
name
net
address
Replied by: Matt K. on 27-05-2010 03:07:57 PM
Thank you. <say-as type="address"> fixed the problem.
Thanks again.
Matt
