Subject: RE: PrecisionHD 1080p Power command
Replied by: Bob Fitzgerald on 13-08-2012 03:42:16 PM
Hello everyone!
One of our customers called in about the same issue. The camera returns a response like it accepted the command, but as Jason pointed out, it only appears as if the camera auto-focused. I am attaching a pic of the commands and responses, as well as a video of the issue in action. The video can be viewed with VLC Player. Upgrading the codec/camera to the latest software had no change in the issue.
Is the power-off command working as intended, or is the command broken, or is the command string different than what is published?
Thanks!
Replied by: Bob Fitzgerald on 12-09-2012 11:11:08 AM
Hi Jonas,
Thanks for the confirmation.
Replied by: Jonas Tysso on 12-09-2012 09:10:12 AM
Hi Bob,
it is not possible to turn the camera off using VISCA.
Cheers,
Jonas
This document was generated from CDN thread
Created by: Jason Meyer on 06-06-2012 07:58:19 PM
What is the correct command for putting a camera into standby?
I have tried this but it just seems to auto focus instead of powering down.
\x81\x01\x04\x00\x03\xFF
Update:
I found by watching the commands sent from the C90 that the Tandberg is not sending the power command to the camera. It is sending a preset location. I have resolved my issue by just sending a preset location command and turning off the LED to show the camera asleep.
\x81\x01\x06\x02\x08\x08\x00\x00\x00\x00\x00\x00\x00\x07\xFF
