This document was generated from CDN thread
Created by: Carl Fitzsimmons on 28-08-2013 03:56:03 PM
I am new to axl and am in the process of loading the demo axl-java-sample-application
Everything is good up to the last step before I can run the app in terminal
I have not been able to load certificate I downloaded from FireFox (saved as cucm9 in documents folder) to the java keystore becuse I do not know the correct syntax for JAVA_HOME
I have looked inside /System/Library/Frameworks/JavaVM.framework/Versions/Current/bin and I do not see keystore which explains why I cannot load 'cucm9' certifdicate to the JAVA keytool
here is what I have been typing that fails:
/System/Library/Frameworks/JavaVM.framework/Versions/Current/bin/keytool -import -alias cucm9cert - file cucm9 - keystore /System/Library/Frameworks/JavaVM.framework/Versions/Current
I am doing this at the 'Documents' folder level
Anyone using OSX that can provide the syntax I should be using?
Thanks ahead of time
Carl
