Putting call on Hold fails
33
This document was generated from CDN thread
Created by: Ofer Shany on 10-05-2010 04:30:12 PM
I'm having problem putting a call on hold in a specific scenario:
1. Agent is in call.
2. Someone dials directly to the agent extension (call fails for obvious reasons).
3. Now agent tries to put his active call on hold.
Result - there is an error in the CTIOS log and I don't get the eCallHeldEvent.
Here is what the ctios log says:
19:09:33 CTIOS1-ctios Trace: [call.5000.8.5001] HOLD_CALL_REQ : (PeripheralID:5000 ConnectionCallID:8
     ConnectionDeviceIDType:0 Reservation:1 ConnectionDeviceID:5001
     UniqueObjectID:call.5000.8.5001 MessageID:eHoldCallRequest ClassIdentifier:3
     CILConnectionID:11
     OriginatingClientID:oshany1_JCIL_Sess(5963049)_EvtThd(24763620)_1340879680896
    206254)
19:09:33 CTIOS1-ctios Trace: Error: Cannot find InvokeID (0x204349) in RequestInfoMap.
19:09:33 CTIOS1-ctios Trace:  Unable to create object for UniqueObjectID []. Discarding args. :
     (Status:17 UniqueObjectIDnull) MessageID:eFailureConf
     MessageType:Unrecognized MessageID: 0?)
It reproduces on ouw own application (our app is implemented in Java) and with the Java test phones.
Does anyone know what this error means ?
Did anyone encounter this before ?
Currently we're working with the simulator since our environent is not up yet - Does anyone know if this has anything to with the problem ?
Ofer
