on 01-25-2014 10:31 AM
David Lender:Yes, CTIOS Cils applications can be multithreaded. Our own Siebel driver is a multi agent mode application. However, a single agent mode session connects to a single CTIOS server, not multiple ones. That said, I see no reason separate agent mode sessions cannot connect to different CTIOS servers.
CTIOS 6.0 is no longer supported. CTIOS 7.5 goes off maintenance shortly. Suggest you use CTIOS Cil 8.5 or later. CTIOS Cils in general are thread safe I have heard of customers creating multi-threaded applications using C++, .NET and Java Cils.
Basudeb Acharyya:
Thank you David for your quick reply. I am new in CISCO CTI world. Let me tell you my thoughts:
Basically I want to utilise your CIL(CTIOS 7.5) library to create a single application that can serve the following things:
1.) Create different CTIOS objects in different threads in the same application to connects to different CTIOS servers.
2.) Each CTIOS object should handle all agents(events and call data) for a particular CTIOS server. Please confirm me whether it is possible or not.
3. Is it possible that we can create a single application in Monitor mode that can handle all agents(events and call data) for all CTIOS servers?
Could you please let me know when CTIOS 7.5 goes off maintenance. This is very importnat for us.
Basudeb
Subject: RE: New Message from Basudeb Acharyya in Computer Telephony Integration Obj
Replied by: Basudeb Acharyya on 18-02-2013 12:31:28 PM
Thank you david. Just one more question:
Currently we are using CTIOS 7.0. As per your mail, it appears to me that currently you aren't supporting any CTI version below 7.5. So if we try to build any application using CTIOS 7.0, we won't get any technical support and maintenence from CISCO. Am I correct?
Basudeb
Replied by: David Lender on 18-02-2013 12:53:26 PM
Per the UCCE 7.0, 7.1 and 7.2 EOL notice here:
http://www.cisco.com/en/US/prod/collateral/voicesw/custcosw/ps5693/ps1001/end_of_life_notice_c51-542058_ps1844_Products_End-of-Life_Notice.html
the end of support for these versions is 2/28/2013, so Cisco will not provide any technical support after 2/28/2013. End of sw maintenance was 8/5/2011 so there are no more maintenance releases for 7.0, 7.1 or 7.2 which means Cisco will not provide any fixes.
Replied by: Shannon McCoy on 18-02-2013 06:07:10 PM
All CTIOS .NET apps are multithreaded. The CTIOS CIL uses an event based asynchronous model which by its nature executes on a background thread. If you check the example code you must ensure that you switch to the UI thread when responding to an event otherwise your app will throw and exception.
As for "thread safety" the CIL is message based and is in essence a fancy wrapper around a set of GED TCP/IP calls to the CTIOS server. As such the CIL per se does not really manage much state in that any state it does maintain is ultimately rectified by the CTIOS server. So while you may maintain a reference to a CTIOS object its really just a wrapper to hold state for essentially what is connectionless/connected model. Bottom line in just about every circumstance the CIL is thread safe.
Unless you have some sort of configuation where the CTIOS servers are non redundant (A/B side) then there is no point to trying to monitor "ALL" servers because only one will be active at time. If the A side server fails then your app should either automatically fail over to the B side ( in Agent Mode ) or you have to add some code to watch for a failure and reinitialize your connection ( in Monitor Mode ). If you try and connect to an inactive server it will simply fail you over to the active one so as I said its kind of pointless.
To maintain muliple sessions you could have a single event processor open the session and dispatch the messages for all sessions which could get messy or you could simply create an even processor for each session and execute the event processor in its own thread, one per session and essentially have multiple silos running in parallell. You could probably even isolate them into their own App Domain if you want even more seperation and process resilency.
It really comes down to what you are trying to achieve and your post is not descriptive enough of your end goal to make an finer detailed assesment. The bottom line is the .NET is fully capable of doing any kind of design you want and the model that the CIL uses lends itself to being used in multiple different ways without too many limitations. The key will be in understanding how to properly mulithread in .NET and using the proper design patterns to achieve your goal. This is generally a far more limiting factor than the CIL is.
Replied by: Basudeb Acharyya on 11-06-2013 04:33:08 PMShannon McCoy:All CTIOS .NET apps are multithreaded. The CTIOS CIL uses an event based asynchronous model which by its nature executes on a background thread. If you check the example code you must ensure that you switch to the UI thread when responding to an event otherwise your app will throw and exception.
Thank you for your reply. Onething is still not clear that whether CIL(ver 7.5) will allow us to write an application that will do the following things:
To subscribe to all events and data for all agents for a particular CTIOS server and should also be able to control each agent state(transfer, Hold etc.).
Basudeb
