remote management/monitoring of in-touch
16
This document was generated from CDN thread
Created by: Steve Hughes on 28-07-2011 09:33:00 PM
an you advise whether there are any xcommands or api hooks into the intouch panel from the codec? We are keep to find a way to be able to remotely check and confirm pairing between the codec and intouch, then even better to be able to reset or reboot if needed in a support situation.
