This document was generated from CDN thread Created by: John Schlimgen on 16-08-2011 03:23:00 PM Can anyone help out? I need to insert a Plus in the the Diversion header User field. The Mask fields listed are all fixed length. The client has a veraible length dial plan.Subject: RE: SIP Normalization Script - Insert Plus for a varable length dial plan Replied by: Yossi Ben Hagai on 08-09-2011 03:37:39 PMYou can try something like the below (haven't tested it):1
2M = {}
3 function M.outbound_INVITE(msg)
4 local div = msg:getHeader("Diversion")")
5 local uri = string.gsub(div, "<", "<+")
6 msg:modifyHeader("Diversion")", uri)
7 end
8return M
Regards,Yossi.
