on 01-25-2014 09:57 AM
Hi Paul,
This handoff would work when there is one inbound and one outbound call , but if both are outbound calls.
In this case, agent make a call to customer and then transfer to IVR for authentication.so two outbound calls
Sandeep,
Currently, the IVR handoff call flow relies on functionality in the incoming call signalling path so won't work on outgoing (or outbound dialer generated) calls. I did sketch out a couple of possible approaches to try to extend this to outgoing call flows but there is no simple way to do it and so far I haven't had time to explore it further as it would require significant changes.
Paul
Thanks Paul for your immediate reply
Hi Paul,
Here we are using an CTI Route point to connect with Handoff ICM script, now if I make a call directly to this CTI route point this is getting failed at second Send To VRU node.
however with one incoming call this works fine, I think it should be at least working while directly dialed from CUCM.
what is your opinion on this
Ravi Sharma
All,
Not sure if this helps, but we have implemented an apporch which allows agent to transfer a call into an IVR and reroute back to the same Agent and in our case it re-routes the transfer call through Syntec and then onto CUBE and back to CVP. Syntec masks out any DTMF and it also takes the payment (and agent can view the customer in real time enter their card number ).
The apporoch is
1) an agent does a warm transfer into a CVP number / IVR. A Warm transfer is required so you can grab the ANI of the Agent (rather than the caller), but its set up specfically in this case to reoute through Syntec
2) The CVP does an SQL query to the AW database so you can determine the Agent ID, (you have the extension, but you need to know the agent).
3) CVP passes variables back to ICM and ICM can do a queue to Agent node and uses queue prioity 1.
In our case the agent is not speaking to teh caller for about 3 seconds, while they do the warm transfer, and press transfer to complete it (and bring teh call back to theselves).
Gerry
Hi Gerry,
In my case Agent is trying to reach the Authentication script via CTI route point however getting disconncet at Send to VRU Node. after I set the Call.SIPHeader value.
hence I was looking for any config If missed.
Ravi Sharma
To start with, just disregard the handoff mechanism and make sure you can make a call from the agent phone/desktop to the CVP application via an ICM script. Once you've got that working OK using the normal CVP Type 10 2-stage Send-To-VRU mechanism, adding in the few extra bits for the handoff mechanism shouldn't introduce any new problems.
Thanks Paul,
when Agent try to dial CTI route point without Handoff it's working, however while IVR handoff this doesn't work.
in this test case I am making a direct call to my CTI without recieving any incoming call.
Ravi Sharma
OK, start by collecting a trace on the ingress/VoiceXML gateway. Turn on "deb voip appl script" and "deb ccsip mess"
