This document was generated from CDN thread
Created by: Ivan Boscolo on 27-10-2010 07:07:16 PM
I want to know if it's possible to read and recall presets previously saved on a system (the section in TMS console, inside a system, is: Extended Settings -> System Status).
I can see my saved preset like:
Preset 1 Defined: True
Preset 1 Type: All
Preset 1 Description: <preset description>
Preset 2 Defined: True
Preset 2 Type: All
Preset 2 Description: <preset description>
Is there a way to read those presets and recall them through the API?
Thanks in advance
Ivan
Subject: RE: TMS: Read and Recall System Presets (Extended Settings)
Replied by: Ivan Boscolo on 27-10-2010 07:10:04 PM
Well, yeah..I've read a notice in the documentation: "The API cannot be used for system management, call management or
other features beyond booking" so I think that this is the answer :-)
