This document was generated from CDN thread Created by: Benjamin Alva on 05-11-2009 04:40:46 PM I've downloaded your module and sample code and it appears to already be setup for serial communication, I have my C60 on com4 so that is the only change I made, I compiled, uploaded and I don't see anything happening on my device notifications, other than the touch panel stuff. Is there more to it, than just download (from you) and load. I just want to see it in action, thanksSubject: RE: Trick to get sample code to work on NI4100 Replied by: Viggo Fredriksen on 05-11-2009 05:09:25 PMHi Benjamin, you should not need to change anything other than the following in the Tandberg_TC_Main.axs file:Change this to com 41dvTandberg_TC = 5001:1:0 // RS232 port 1 real device
Ensure that the Baud_Rate and Password properties are the same as the C60 configurationbefore sending REINIT to the module. The section can be found towards the end of the file. 1(***********************************************************)
2(* THE EVENTS GO BELOW *)
3(***********************************************************)
4DEFINE_EVENT
6DATA_EVENT[vdvTandberg_TC]
7{
8 ONLINE:
9 {
10 // Set the IP address if using IP control (default=<na>)
11 // send_command vdvTandberg_TC,'PROPERTY-IP_Address,'
12
13 // Set the RS-232 baud rate (default=38400)
14 send_command vdvTandberg_TC,'PROPERTY-Baud_Rate,38400'
15
16 // Set a password (default=TANDBERG)
17 // send_command vdvTandberg_TC,'PROPERTY-Password,TANDBERG'
18
19 // Re-initialize the module for the properties to take place
20 send_command vdvTandberg_TC,'REINIT'
21 }
22}
Subject: RE: Trick to get sample code to work on NI4100 Replied by: Benjamin Alva on 05-11-2009 07:52:22 PMYes, we have it set as you have shown, but for some reason we don't see the Virtual Device online. I have the panel and the master, but no Virtual Devices, we looked for any typos, but can't find any, BenSubject: RE: Trick to get sample code to work on NI4100 Replied by: Benjamin Alva on 05-11-2009 08:12:34 PMIt was figured out for me, the firmware on the controller was 1 rev too old I guess, it's working now that we updated the firmware on the controller, that information is probably on the documentation that i sped through, if not it might be helpful to add, thank you for the quick answer to my question, I'm sure there'll be moreSubject: RE: Trick to get sample code to work on NI4100 Replied by: Tyler Geddes on 20-10-2010 09:06:40 PMViggo Fredriksen:
Hi Benjamin,
Ensure that the
Baud_Rate and
before sending
4DEFINE_EVENT
7{
8 ONLINE:
9 {
12
15
18
21 }
22}
When I change the baud rate on this line to 19200 the netlinx controller still sends out a command to the TANDBERG as the module initializes that says "Command To [5001:1:1]-[TSET BAUD 38400,N,8,1,485 DISABLE]"Is there any other place that one must change the baud rate within the AMX module?
