This document was generated from CDN thread Created by: Chandar vr on 09-09-2009 10:02:25 AM Hi, I have written a small perl script to execute a sql query and return the data after the execution. But i am getting the error Null SQL statement. I am attaching the code below 1 2#!/opt/perl/bin/perl
3print "Content-type: text/html\n\n";
4use SOAP::Lite +trace;
5BEGIN {
6sub SOAP::Transport::HTTP::Client::get_basic_credentials {
7 return 'user' => 'pwd';
8 }
9}
10$cm = new SOAP::Lite
11 uri => 'file:/path/AXLAPI.wsdl',
12 proxy => "[url= ]https://[cucm]:8443/axl/[/url]";13print "this is ".$cm;
14$res = $cm->executeSQLQuery("select * from device");
1516unless ($res->fault) {
17 print Dumper($res->paramsall());
18 }
19 else {
20 print join ', ',
21 $res->faultcode,
22 $res->faultstring;
23}
Please help me on this ..Subject: RE: Using perl for accessing AXl Replied by: Thomas Beck on 12-10-2009 07:02:29 PMHi,try this litte example: 1 2#!/usr/bin/perl
3 4use warnings;
5use strict;
6use SOAP::Lite;
7use Data::Dumper;
8 9my $DEBUG = 1;
10my $cucmip = '127.0.0.1';
11my $axl_port = '8443';
12my $user = 'AXLUSER';
13my $password = 'AXLPASS';
14my $error_text;
1516BEGIN {
17 sub SOAP::Transport::HTTP::Client::get_basic_credentials {
18 return ($user => $password)
19 };
20}
2122use SOAP::Lite +trace => 'debug';
2324my $cm = new SOAP::Lite
25 encodingStyle => '',
26 uri => 'http://www.cisco.com/AXL/API/1.0',27 proxy => "https://$cucmip:$axl_port/axl/" ;2829my $axl_sql = "SELECT * FROM device";
3031print "\$axl_sql: $axl_sql\n" if ( $DEBUG==1);
32my $data = SOAP::Data->name( "sql" => $axl_sql );
33my $res = $cm->executeSQLQuery( $data );
34unless ($res->fault) {
35 $Data::Dumper::Indent = 3;
36 print Dumper($res->paramsall()) if ( $DEBUG==1);
37} else {
38 $error_text = $res->faultcode.' '.$res->faultstring."\n";
39 print $error_text;
40}
Hope this will help you.
