Visca Control of 1080p 12x Zoom Camera
160
This document was generated from CDN thread
Created by: Chris Audette on 09-02-2010 04:36:12 AM
Gentlemen,
Hope all is well in Oslo!
I have a consultant that would like to specify 12 cameras with a visca controller.
1) Should I have any concerns about controlling these with a Sony joystick?
2) Are you aware of any limitations with the amount of cameras on a visca chain?
3). Are the cameras velocity sensitive?  Will the cameras move faster holding the joystick longer?
Thanks!
Chris
Subject: RE: Visca Control of 1080p 12x Zoom Camera
Replied by: Roger Boe on 16-02-2010 10:00:01 AM
Hi Chris,
1)  We do support the Visca protocol, so in theory this should work just fine. However we have not tested it with such a Sony joystick so it should be tested and verified.
2) The Visca protocol is limited to 7 cameras and this is what we support.
3) We do support speed as a parameter when controlling the camera. It doesn't do this automatically, so you would have to specify a command to tell it what speed to use when moving the camera.
Best regards
Roger
