on 01-25-2014 10:01 AM
I'm using a 'voice element - digits' that occasionally fails to work correctly. Most of the time (about 90%), the workflow enters the element, the audio file defined in the element plays, the user enters a value, and the workflow exits the element with a 'done' exit state:
(from the Activity logs)
99.99.99.99.1326983030057.66801.app1,01/19/2012 09:26:46.665,Prompt_EnterZipCode_02,enter,
99.99.99.99.1326983030057.66801.app1,01/19/2012 09:26:55.915,Prompt_EnterZipCode_02,exit,done
But occasionally (about 10%), the workflow enters the element, does not play the defined audio file or accept any user input and the session eventually goes to completion:
99.99.99.99.1326982073250.66654.app1,01/19/2012 09:10:52.484,Prompt_EnterZipCode_02,enter,
99.99.99.99.1326982073250.66654.app1,01/19/2012 09:16:11.278,,end,how,app_session_complete
Has anyone seen this behavior or have any suggestions on what might be happening?
We're using CallStudio - 6.0(1), CVP 4.1
Jay Van Cott
Hi Jay, The ',end,result,timeout' in the Activity Log means that VxmlServer timed out waiting for the gateway to return with the caller's response. So, there's definitely an issue on the gateway. In your Studio application, under Project>Properties - what is your Session Timeout set to? My guess is 5 (or 6) minutes - as that's the lag time in the Activity Log between entering the element and timing out. In Project > Properties, try setting the VoiceXML Property Name: fetchtimeout Value: 60s Then if the gateway can't connect to a media server in 60s, it'll return the 'error.badfetch' response to VxmlServer - and at least you'll know what the issue is. Is it possible that one of your media servers is down? or that the audio file doesn't exist? Janine
