What the different between CGport and listen port? heart beats port?
185
This document was generated from CDN thread
Created by: Yasser sayed on 03-02-2010 09:10:58 AM
Dear sir ,
i try to implement an appliaction using java language using simulator
1- i configure two host as host ip ="localhost"  and port ="42027"
2- conigure protocol version to 11 decimal (regedit)
3- configure in heart beats screen listen ip "42028"
when t tried to connect usin 42027 port connection refused and when i use 42028 the connection done
Subject: Re: New Message from Yasser sayed in CTI Server Protocol (GED-188) -  CTI S
Replied by: Yasser sayed on 03-02-2010 01:40:55 PM
Dear Sir ,
   I need ur support as soon as possible
best regards,
On Wed, Feb 3, 2010 at 12:10 PM, Cisco Developer Community Forums <
cdicuser@developer.cisco.com> wrote:
> Yasser sayed has created a new message in the forum "CTI Server Protocol
> Questions":
> Dear sir ,
> To respond to this post, please click the following link:
> http://developer.cisco.com/web/ctisp/forums/-/message_boards/message/1943954
> or simply reply to this email.
Subject: RE: New Message from Yasser sayed in CTI Server Protocol (GED-188) - CTI Se
Replied by: David Lender on 03-02-2010 02:21:55 PM
What simulator are you using?  42028 is usually the port number for
CTIOS Server rather than CTI Server.
Replied by: Yasser sayed on 03-02-2010 04:20:01 PM
Simulator VERSION 2.0.0.0 in CTIOS cd  version  7.5.1
Replied by: Yasser sayed on 03-02-2010 04:23:11 PM
Dear David
FYI
when i change listen port from 42028 to another port as 42031 it will connect using 42031 and not old port 42028
Replied by: David Lender on 03-02-2010 05:08:55 PM
The simulator simulates CTIServer for connection by CTIOS Server.  The
CTIServersim does not support direct connection by a cti server protocol
application.  Also, CTIServersim is provided "as is" and not supported
by Cisco.
