on 01-25-2014 10:33 AM
David Bruun-Lie:Jaroslav, the xFeedback command is a per-session setup so yes you will need to have a connection open to have any benifit of it. You may have a large number of connections open. However, why would you want that? What is your controller source? AMX/Crestron/PC Application/mobile application?
David Bruun-Lie:Have you read the API howto guide? http://developer.cisco.com/web/telepresence-developer/howtos/cseries-api/feedback
Enrico Conedera:Regarding xEvents, you can get a list of all supported events from the API. The following happens to be from an EX90:
[image.png]
regards/
/enrico
sent from my iPhone
On Feb 26, 2013, at 9:40 AM, "Admin Tandberg Developer" <cdicuser@developer.cisco.com<mailto:cdicuser@developer.cisco.com>> wrote:
Jaroslav Urban has created a new message in the forum "Codec C90/C60/C40": -------------------------------------------------------------- Hi David, thanks for reply.
David Bruun-Lie:
Yep I found info its per session aka per connection. I dont want to really mess with connections. In my view it's ok to keep open 2 connection, one for xFeedback, second for any xCommand, xStatus processing. It would probably work also to have just one connection open I guess.
In my case its WPF application which will be communicating with TelePresence C60. Implementation should support both option, connection over serial port or over tcpip.
David Bruun-Lie:
Well, I saw it before, but I missed it. So thanks, it gave me some more info then API ref. However still I am missing more information abour events. Why dont you list them in API ref as the rest (xCommand, xStatus, etc.)?
One more question, how C60 handle errors? If any error occurs at C60 during e.g. xCommand processing, what is returned? I can not find any info around.
Thanks.
Cheers, Jaroslav
To respond to this post, please click the following link: http://developer.cisco.com/web/telepresence-developer/forum/-/message_boards/view_message/12391006 or simply reply to this email.
Enrico Conedera:Sorry, the graphic did not come through.
In the API, use the command "xEvent ?"
This will provide a list of all supported events for the particular product.
xfeedback register /standby/active
xfeedback register /conference/presentation/mode
xfeedback register /status/autoanswer/mode
xfeedback register /configuration/video/selfview
