This document was generated from CDN thread
Created by: JAMES PERLOWSKI on 09-09-2008 05:24:28 PM
We seem to have an issue with a 5350 with a T3 passing the UUI field from CVP 7.0.2. It has worked fine with a 5350 that has a T1 installed. We have TAC working on the case, but this is holding up production deployment, and I wanted to find out if someone may have run across such an problem
Subject: Re: 5350 T3 with UUI issue
Replied by: MICHAEL CLENDENING on 18-09-2008 04:25:14 AM
What version of IOS are you running? This is known problem in certain 12.3x versions of code...see bug ID: CSCeb50563
Assuming you did not move from H323 to SIP (which requires some call server config) and your gateway app has the required "param use-uui-as-corrid Y" (if using Correlation ID to GTD).
Apologies if this seems elementary...as these are the typical problems I have seen with this.
Peace,
Michael Clendening
CCIE 6487 (ISP-Dial)
