Manish Gogna
Since a lot of queries are coming up regarding the Bash bug, posting the bug link for the same here
https://tools.cisco.com/bugsearch/bug/CSCur00930/?reffering_site=dumpcr
Symptoms:
The Cisco Unified Communications Manager (UCM) 10.0 includes a version of bash that is affected by the vulnerabilities
identified by the Common Vulnerability and Exposures (CVE) IDs:
CVE-2014-6271
CVE-2014-7169
This bug has been opened to address the potential impact on this product.
Conditions:
Devices with default configuration.
Workaround:
Not available.
Further Problem Description:
PSIRT Evaluation:
The Cisco PSIRT has assigned this bug the following CVSS version 2 score. The Base and Temporal CVSS scores as of the time of evaluation are 7.5/7.5:
https://intellishield.cisco.com/security/alertmanager/cvssCalculator.do?dispatch=1&version=2&vector=AV:N/AC:L/Au:N/C:P/I:P/A:P/E:H/RL:U/RC:C
The Cisco PSIRT has assigned this score based on information obtained from multiple sources. This includes the CVSS score assigned by the third-party vendor when available. The CVSS score assigned may not reflect the actual impact on the Cisco Product.
Additional information on Cisco's security vulnerability policy can be found at the following URL:
http://www.cisco.com/web/about/security/psirt/security_vulnerability_policy.html
Aman Soi
Hi Manish,
I could find ciscocm.bashupgrade.cop.sgn available on below Cisco site
http://software.cisco.com/download/release.html?mdfid=284603371&softwareid=282204704&release=COP-Files&flowid=45680
Any advise how do we proceed to exexcute this cop file , we have got CUCM 9.1(2)SU1?
regds,
aman
Manish Gogna
Hi Aman,
The installation requirements and process for the same is outlined in the read me file here
http://www.cisco.com/web/software/282204704/18582/CiscoBashCodeInjectionVulnerabilityPatchv2.pdf
Manish
Aman Soi
Thanks Manish for the same[+5].
Let me take call with customer so that we can apply the same.
there is a similar discussion in which show tech version is being discussed .
https://supportforums.cisco.com/discussion/12311531/cucm-shellshock-versions#comment-9986951
Any idea if we could check something related to bash.
regds,
aman
