TCC_2
Advocate
Advocate
Core Issue
When the call is made through the Public Switched Telephone Network (PSTN), the call is completed successfully.
Resolution
This problem is observed when the remote sites use a non-G711 codec. Cisco Customer Response Applications (CRA) currently support only the G711 codec. Use a transcoder to resolve this issue or change the codec to G711 at the remote side, if possible.
To configure transcoding resources, refer to these documents:
