David Orzelek
Problem Description
Timing of shroud light power down in CTS v1.7
Conditions / Environment
Normal operation
Root Cause
NOTE: This information pertains to systems with their CUCM profile set to "On with calls only"
Generally, the lights turn off after 15 seconds for personal systems (CTS-500, CTS-1000 for example) and the public room systems turn off after 5minutes (CTS-3000, CTS-3200)
  • For the 500 unit, this is configured in the CUCM profile under Product Specific Configuration Layout under Lights.
  • For the 3xxx and 1xxx models with an ACU, it is configured under the CUCM profile under Auxiliary Control Unit - Power Control.
  • The trigger to turn off the lights varies depending on the system type and setup
Summary of the differences:
CTS ModelLight Timer
50015 seconds
1xxx15 seconds
3xxx5 minutes
Exceptions:
  • If there is presentation plugged in or a DMP is connected, the system will turn the lights off after 15 seconds regardless of system type.
  • There were some inconsistencies in shroud light shutdown times in pre 1.7 code.
For additional information see:
