Jawad Al Akrabawi
This is an example on how to deploy Cisco CMS2.9 with Selfsigned Certificates for training/test purposes only. It is not meant for production networks, there is no integration with AD or CUCM, but should enable you to login to the CMS as guest with predefined spaces. Selfsigned certificates limits some features of CMS and should never be used in production networks.
This document will use the new Webbridge3 in CMS without the need to configure XMPP, and it will demonstrate the new GUI API function in CMS.
Ayodeji Okanlawon
Thank you for this. Very helpful. Do you know  how I can get a demo license?
Jawad Al Akrabawi
You can contact your local Cisco Account Manager (AM) or Systems Engineer (SE) to get a demo license.
abdul rasheed
Hello Jawad,
Good work. Really appreciate. Is there anyway cisco has detailed documentation about individual templates (like cospace, call leg, and call profiles)? Unfortunately, there is no chat option in WebApp. and there is no option to get it working using Jabber for Randezvouz calls and individual spaces!
