Pablo Leiva
Beginner
Beginner
CRS 4.0(4) - steps should be similar for recent UCCX versions.
Step 1
- Log into Cisco Desktop Administrator from the CRS server (Start> Programs> Cisco> Desktop> Desktop Administrator)
- Browse into the CRS Server> Desktop Configuration> User Interface (you can create a new Work Flow or use default)
Step 2
- Here we'll add the Start Recording and Stop Recording buttons for the CAD agents.
- Choose Task1 and select the 'Visible' box on the right pane
- Add Action - select Utility Action - Add new...
          Action Name: Start
          Action Type: Record
          Action: Start
- Customize icon as desired
Step 3
- Add similar Action for Task2...
           Action Name: Stop
           Action Type: Record
           Action: Stop
Step 4
- Make sure that the agent has this Work Flow selected.
Step 5
- Log out this agent from CAD and log in back again. Now the new tasks are available and agent can record it's calls.
Walter Solano
Rising star
Rising star
Nice!
Recognize Your Peers
