on 01-24-2014 11:57 AM
Did you get any solution. I am trying to work on something similar to this.
When there is an incoming call
I need to get the phone number and check our oracle database, get the information and send the data back to phone again to display the message I sent.
Can you provide me some help doing this. thank you.
However, there is no Answer URI that I can send with the <CiscoIPPhoneText> object.
