TCC_2
Level 10
Level 10
Core Issue
If different packet marking schemes are used in different parts of a VoIP network, then it is necessary to be able relate the values to each other to ensure consistent QoS characteristics across the network.
Resolution
This table compares QoS values for IP precedence, Differentiated Services Code Point (DSCP) and Multiprotocol Label Switching (MPLS) Experimental (EXP) values along with standard values used in Cisco IOS  Software for configuration. For an introduction to this topic, refer to QoS for VoIP.
Per Hop Behavior (PHB)DSCP valueDSCP bitsIP precedence and Class of Service (COS) value (xyz000)Comment:MPLS EXP bits
Default00000000=routine
  • Best effort
2000010
3000011
4000100
5000101
6000110
7000111
CS180010001=priority
AF1110001010
  • Assured forwarding class 1 (001)
  • Drop priority 010 (1)
  • Dropped last in AF1 class
11001011
AF1212001100
  • Drop priority 100 (2)
  • Dropped 2nd in AF1 class
13001101
AF1314001110
  • Drop priority 110 (3)
  • Dropped first in AF1 class
15001111
CS2160100002=immediate
AF2118010010
  • Assured forwarding class 2 (010)
  • Dropped last in AF2 class
19010011
AF2220010100
  • Dropped 2nd in AF2 class
21010101
AF2322010110
  • Dropped first in AF2 class
23010111
CS3240110003=Flash
AF3126011010
  • Assured forwarding class 3 (011)
  • Drop priority 1 (010)
  • Dropped last in AF3 class
27011011
AF3228011100
  • Drop priority 2 (100)
  • Dropped 2nd in AF3 class
29011101
AF3330011110
  • Drop priority 3 (110)
  • Dropped first in AF3 class
31011111
CS4321000004=FlashOver
AF4134100010
  • Assured forwarding class 4 (100)
  • Dropped last in AF4 class
35100011
AF4236100100
  • Dropped 2nd in AF4 class
37100101
AF4338100110
  • Dropped first in AF4 class
39100111
CS5401010005=critical
42101010
43101011
44101100
45101101
EF46101110
Recommended Expedited Forwarding (EF) value (used for voice        traffic)
47101111
CS6481100006=internet
6
49110001
50110010
51110011
52110100
53110101
54110110
55110111
CS7561110007=network
7
57111001
58111010
59111011
60111100
61111101
62111110
63111111
aung-thura
Thank you for your comparison chart. I would like to know if there any practical usage of dscp values like 1,2,3,4,5,..63 (not include the AF, CS, EF, Default value). Why only some of the numbers are assigned for AF, CS and why other values still left in plain numbers?
