    Introduction
    This document explains how to configure the H.323 PRI and Gateway integration with the Cisco Unified Communications Manager (CUCM)10.x
    Follow these steps to add H.323 gateway to CUCM:
     Add a H.323 Gateway to CUCM 10.x
    1: In CUCM 10.x Administration, Choose Device > Gateway.
    2: Click the Add New button.
    3. Select  H323 Gateway for gateway type and
    4. Click Next
    5. On the Gateway configuration, enter
    Device name: 10.1.1.5 (H.323 Gateway IP address)
    Description:
    Device pool: Sanjose / Default
    Signaling port : 1720 by default
    Leaver other parameters to Default
    6. Click Save
    7. Click Reset button and Check whether the IP Address of the Gateway appears
    Configure the Voice Gateway for H.323 PRI
    To Configure the Voice Gateway for MGCP PRI,
    Open a telnet session to the router say at “Site-2” using putty
    Router# configure terminal
    Router(config)# isdn switch-type primary-ni command
    Router(config)# network-clock-participate wic 0
    Enter the controller configuration with
    # Controller t1 0/0/1
    framing esf
    linecode b8zs
    pri-group timeslots 1-24
    Type, # no shutdown
    Enter # Exit - to leave the controller configuration mode
    Enter interface configuration mode
    # interface fastethernet 0/0
    H323-gateway voip bind srcaddr 10.1.1.5
    Exit
    Enter a dial-peer and destination patter
    # dial-peer voice 1 voip
    # destination-pattern 144123456…
    Session target ipv4: 10.1.1.10
    Exit
    Enter dial-peer voice pots to create dial-peer for PSTN
    # dial-peer voice 2 pots
    destination-pattern 9.T
    direct-inward-dial
    port 0/0/1:23
    # Exit - to leave dial peer configuration mode
    # Exit – to leave configuration mode
    # write – to save router configuration
    Related Information
    Excellent
    Excellent document for fresher persons.it is very useful for me.
    kingstdz
    hi
    thanks, what about making call from external pstn like 0x xxxxxx * xxxx  to internal (after * is number of ip phone in 4 digits)
    thanks
    Mk23
    Can somebody explain with scenario, when do we check "wait for far end H.245 Terminal Capability Set"in h323 gateway?
