Core Issue
On Cisco CallManager 4.x with MobilityManager when the Mobile Connect feature is used, an inbound call rings an IP phone as well as a cellular phone, but when the call is answered from the cellular phone, the call drops and the calling party hears a busy tone. If the call is answered from the IP phone, everything works fine.
Resolution
In order to resolve this issue, complete these steps:
- First update the Java Telephony API (JTAPI) Plugin from the Cisco Unified MobilityManager Administration Window.
- Choose System > System Parameters.
- Change Enable Auto Update JTAPI File, and choose Yes to Always Update JTAPI File.
- Also, uncheck SSL for CCMPluginsServer in IIS Manager.
- If there is a phone in the remote site, make sure that the Transcoder is added to the media resource gateway list (MRGL).
