Payal Bhaduri
There is a general misconception that IP addresses were allocated per audio source ID.  For example:
Audio Source
Codec
Increment Multicast on IP Address
Increment Multicast on Port Number
Destination IP Address
Destination Port
Destination
Port
G.711 mu-law
239.1.1.1
16384
239.1.1.1
16384
G.711 a-law
239.1.1.2
16384
239.1.1.1
16386
G.729
239.1.1.3
16384
239.1.1.1
16388
Wideband
239.1.1.4
16384
239.1.1.1
16390
G.711 mu-law
239.1.1.5
16384
239.1.1.1
16392
G.711 a-law
239.1.1.6
16384
239.1.1.1
16394
G.729
239.1.1.7
16384
239.1.1.1
16396
Wideband
239.1.1.8
16384
239.1.1.1
16398
However, the fact is, IP address allocated based on the order the audio source was configured.  For example, if you configure audio source 2 before audio source 1, the table would be like this:
Audio Source
Codec
Destination Port
Destination
Port
G.711 mu-law
239.1.1.5
16384
239.1.1.1
16392
G.711 a-law
239.1.1.6
16384
239.1.1.1
16394
G.729
239.1.1.7
16384
239.1.1.1
16396
Wideband
239.1.1.8
16384
239.1.1.1
16398
G.711 mu-law
239.1.1.1
16384
239.1.1.1
16384
G.711 a-law
239.1.1.2
16384
239.1.1.1
16386
G.729
239.1.1.3
16384
239.1.1.1
16388
Wideband
239.1.1.4
16384
239.1.1.1
16390
You may use SQL command to check this in DB:
admin:run sql select mohaudiosourceid, multicastaddress, multicastport from mohservermulticastinfo where mohaudiosourceid='4'
mohaudiosourceid multicastaddress multicastport
4                239.1.1.1        16384
4                239.1.1.2        16384
4                239.1.1.3        16384
4                239.1.1.4        16384
If you wish to get a list of all MOH audio sources with multicast IP address, port, and codec you can use this query.
run sql select m.mohaudiosourceid,m.multicastaddress,m.multicastport,c.name from mohservermulticastinfo as m,typemohcodec as c where m.tkmohcodec = c.enum
mohaudiosourceid multicastaddress multicastport name
1                239.1.1.25       16384         711 ulaw
1                239.1.1.25       16386         711 alaw
1                239.1.1.25       16388         729
1                239.1.1.25       16390         wideband
Steven Griffin
Level 4
Level 4
Excellent post!
Tsungs102
This really helped me clear up the misconception.  Thank you.
I was able to stream MoH from local flash after finding out audio source 1 is 239.2.1.1 in our environment.  However, this only worked for user hold but not when UCCX attempts to consulted transfer.  For some reason, during the consulted transfer the multicast address it uses is 239.2.1.5 and it is not coming from local flash and becomes garbled.
Do you know how that can be fixed?
Sam
