This document was generated from CDN thread
Created by: Enrico Conedera on 31-01-2012 08:35:34 AM
hello - that camera does not output 1080p - it is specified at 1080i - interlaced.
However, it does support a 720p signal at 50Hz. If you force the output to that setting on the camera, then it should work on HDMI. Possibly on HD-SDI as well.
regards,
enrico
