Matthew Limbrick
When  replacing a T3 codec via RMA, it will most likely not have the correct  Product ID and option keys installed on it. Below is how to verify and  create them if needed.
Product ID:
Ensure  that the Product ID is "Tandberg T3" instead of "Tandberg Codec C90"  with the following command. Below is the output it should be. If  different, generate the correct product ID. You may need to contact  logistics to update their systems to reflect.
xstatus systemunit Product
(Center)
*s SystemUnit ProductType: "TANDBERG Codec"
*s SystemUnit ProductId: "TANDBERG T3 Center"
*s SystemUnit ProductPlatform: "C90"
(Left and Right)
*s SystemUnit ProductId: "TANDBERG T3 LR"
(Incorrect)
*s SystemUnit ProductId: "TANDBERG Codec C90"
Option Keys
Ensure the following options keys are installed as shown by using the  command below. The center codec needs all option keys while the left  & right codecs only need the premium resolution option.
xstatus systemunit software optionkeys
(Center) All options are needed
*s SystemUnit Software OptionKeys NaturalPresenter: "true"
*s SystemUnit Software OptionKeys MultiSite: "true"
*s SystemUnit Software OptionKeys PremiumResolution: "true"
(Left and Right) - Only PremiumResolution option is needed
*s SystemUnit Software OptionKeys NaturalPresenter: "false"
*s SystemUnit Software OptionKeys MultiSite: "false"
To generate Product ID
Reach  out to Licensing by emailing licensing@cisco.com or calling 1-800-553-2447, and inform them the C90 codec you received has the  wrong Product ID. Provide them with one of the part numbers below so  that they can generate the correct key.
1P005 - Product Key T3 Center (SKU LIC-T3-CTR)
1P006 - Product Key T3 LR (SKU LIC-T3-LR)
